Buy better quality fuel and go for a long drive?
I'll be fascinated to find out the answer to this question!
http://www.mbclub.co.uk/forums/showthread.php?t=12235
I'm getting more convinced that this problem is down to fuelling.
I think you are right.
I filled up in Tesco in Dublin (which is supplied by Statoil here) and last week and this week on two separate occasions my CLK55 misfired. It only happened when I went to kick down, and then started to wobble like a 1920s plane. Furthermore, when stopped with this happening, the idle was very rough (you could feel it through the brake pedal). This all went when restarted, so I drove home and left it as I was away for weekend.
Came back yesterday, same thing, no problems until putting the foot down, the misfire putt-putt-putt with a big drop in power. Stopped, restarted and it was gone.
Anyway, after reading the forums, it seemed that the simplest first step was fuel, then plugs (changed 6000km ago) and then leads, etc., before thinking crazy things like the CAT, etc., .
So I filled up with V-Power (it is 95RON in Ireland but has engine cleaning stuff apparently), on top of a quarter of a tank of the Tesco stuff, and went for a 120km spin, and basically now it's silky smooth, and kickdown is clean all the way to the redline, including the change up (but not too many, as it will do 240kph in 4th gear!).
So, I am thinking, dodgy fuel by Tesco, they must water it down in some way, as it is cheaper by far here. I couldn't kickdown without a misfire yesterday and having gone through the 15 litres of what was left, and another 15 litres or so all in one trip, I am having no problems.
Also, I never got any engine management lights, or check engine, etc., at all, not a single error or warning.
