The seal fits into the black metal housing which I presume is either bonded to the glass or press fitted. The seal may not even be glued into the housing but just pushed in. Wouldn't go anywhere with a heat gun that's for sure. I'd be using a plastic trim tool to prise out, but get the replacement first!Hi the seal attached on the rear windows in place where a b-pillar should of been on the C215/216/217 seems to have reached its end of life on my car. Anyone aware how they can be replaced? They seem to be glued on the window. I guess a heat gun will ruin the laminate on the window?
OK thanks for confirming. I will give it a go soon.When I replaced mine I didn't use any sealing cord.
Old one slid up and off, new one needed some soapy water to slide down. I used a little bit of black window sealant on the top part.
Been the best part of 3 years now and I've had no issues with wind noise or anything.
