CL500 pollen filter location/changing
jasohal
London
S320 E500 E55
Guys,
1. Where the funk are these ?
2. How the funk do I change them ?
I had a look under the dash on the passenger side and found some quite dirty Charcoal filters, but no sign of the rectangular pollen filters.
Looking at the bosch website it seems these are in the glove box ??
Is this right ? how do I get to them...
cheers
hi yes thay are behind the glove box
open the glove box there are two screws at the top and screws at the bottom poss covered by a small black plastic cover
then pull the glove box out tight but will come out disconnet the glove box light
there then will be the casing for the filters in front of you remove it by slideing it to the side and there will be the filters remove both the filters and replace
Top Man !!!
I will get at these tomorrow when theres some light...
Cheers for the rapid reply !!
If its a W140 CL then it may be located in the engine bay, bottom right corner of photo is where it sits as thats where it is in the S Class W140.
Its not a hard job, just time consuming!
