CL55 AMG 2001 w215
higs
Middlesex
CL55 AMG
Dear all,
I currently have a CL55 AMG 2001, and just recently my Heater has stopped working. i am hoping that the fuse has blown and can be easily fixed, however i cannot find the fuse diagram supplied with the car. i was hoping some of you nice MB owners would kindly upload or email me a copy?
Your help will be really apreciated.
Higs
The fuse is in the box under the bonnet on the right hand side. A 40amp i think. I would check ofr water entering the car via the heaterbox due to the drain blocking up under the bonnet as this can cause premature blower failure. If its wet look under the bonnet and on the left hand side there is a grill that lifts off. if its full of water the drain will be blocked letting water in through the fan air intake. There is also a sercice measure for some cl /s class heater wiring. See the main dealer and they will check for you.
