Any thoughts on loss of central locking and keyless go on 2003 (facelift bi-turbo CL600) - doors lock/unlock from buttons on dash, so maybe a signal problem??
Key starts car etc, but remotes don't lock the car and the keyless doesn't work either - when button is pressed dash says key not recognised
Before I head off to dealer - didn't know if this is a common issue or an expensive fix as I assume the system is pretty technical!
