paul73mt
- Jul 18, 2012
- Location
- Great Britain
- 2010 C350 CDI Sport sold , 2015 E250 CDI AMG Line Sold
Well I've now got the car as all is well but have got a couple of niggles with it would these be covered by the warrenty and if so how do i go about making sure it's done under warrenty.
1. Drivers wingmirror squeaks and folds in/out slow and sometimes when folding in the motor seem to try and drive it in futher even though the wing mirror is touching the doors crome strip.
2. The rear near side tail light has got a connector on it and one of the pins (brown core) has got hot and melted slightly the plastic around it and also the cable harness pin is brown and loose (does also give so messages saying tail light out)
3. not always but the engine seems to be noisy. and after i have used the lever to drop a gear or two and then put it back to auto the gearing is all over the place as in when i slow down it not dropping a gear and the rev's are going below a 1000rpm so the when you want to pull away it drops a couple or could be 3.
Thanks in advance
Paul
Car was registered in March 2010
Thanks in advance
Paul
