Clattering from underneath
Nasco12
Twickenham
W202 C240 1999 Green; Previous: W202 C200
Here's what happens:
Start up - go to the supermarket - stop - return to car 15-20 mins later - start up - metallic clattering from underneath - move off - clattering ends.
This does not happen when starting from cold - only when the engine is warm. If I get out of the car to have a look it disappears.
Tonight as I was slowing down at the end of my journey I heard the same clattering. This is the first time it has happened when the car has been in motion.
Any ideas?
BlackC55
Portsmouth, Hampshire.
E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Loose exhaust bracket?
Broken exhaust mount?
Loose CAT?
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
Parking brake cable loose? Or is that only the 203?
whitenemesis
MB Club Veteran
:doh: :eek:
A-AvantGarde
South Bucks
2016 BMW F86 X6 M, 2016 BMW F30 320d, 2001 Mercedes C320 Elegance
Sounds like it could be a broken Catalyst or exhaust mountings...
Rorcus
2001, E320 CDI
:) yep definitely sounds like a piece of the honeycomb in the cat has broken away.. Once warm the cat expands enough to give it more room to rattle, then often when moving off it can slide/move back and wedge causing the sound to stop and can then come back as you decelerate as it moves free again.
Youtube search "Cat rattle" and you should find an example that probably sounds just like yours. :D
whitenemesis
MB Club Veteran
I believe some have 'cured' this by slightly crushing the casing to hold the honeycomb.
Rorcus
2001, E320 CDI
Cat rattle? Sounds expensive.
Not too bad.. (if it is the cat.) New Downpipe with cat can be got for around £100 and then bung a friendly Exhaust Centre £30-40 to fit it (Grays Tyre & Exh Cent on Heath Road Twick are pretty good, I took my Shogun there with a complete system in the boot inc cat and D/Pipes and he fitted the lot up for £70)..
pc-uk007
LONDON
2001, W220, S320L, petrol,
I had this problem last winter, metalic rattle at times stationary and if i had window open sometimes as i pull away from stand still any other times no noise heard,(no engine light illuminated) it will get worse when it does just take it to exhaust centre for inspection. mine was the cats at 90,000 miles.
mirras
Ayrshire
Range Rover TDV8
My car developed a rattle from underneath a few weeks ago... turned out to be a heat shield that 'fell off'... £1.95 worth of penny washers and it was back on as good as new.... fingers crossed that's all it is for you, wiggle a few bits when the car is cold to see if you can recreate the noise.
OP
OP
Nasco12
Nasco12
Twickenham
Turned out it was either a loose heatshield or an exhaust bracket that had become detached from the exhaust pipe.
Jack at PCS sorted out both. Many thanks.
mirras
Ayrshire
Range Rover TDV8
Always good when a worrying problem turns out to be an easy fix :bannana:
