I have 17 inch AMG alloys with the polished rim.. Do you have any advice on getting the rim back to mirror finish and then keeping it like it.. I want a DIY solution not send them off @£60 per wheel
You should be able to use the same polish as you use on your paint work to keep them shiney. After cleaning them, I use Meguiars Hot wheels, depends how bad they are.
I've cleaned them ok ie no dirt at all on the lip., but they do not shine....I guess I need to use some kind of cutting compound or similar but am not sure...
I am no expert on polished rims but a friend of mine just used the same polish for his paint, they always shined. You will get more replies later, but you could try g3 etc.
Will have to invest in lots of elbow grease byt the sounds of it. Is it possible to use any type of electric polisher on the rims or will they cause damage??/
