ALFIE CONN
- Mar 30, 2007
I know there has been a thread on this already, i have looked for 25minutes but cant find it.
Help appreciated!
Help appreciated!
If you do a search under BIRD SH*T a couple of threads turn up. One guy swears by a product called Dulon. http://www.dulon.com/index2.html Consensus seems to be the application of a protective layer before the event. Not much info what to do after the "incoming" event unfortunately.
I believe the standard Royal Flying Core "Biggles" Flying helmet and goggles is suitable attire for a gentleman in these circumstances. The white silk scarf is unnecessary and an affectation in my opinion.Does that stuff work on you when the roof is down
Wish I'd had this info a while back. I have a patch on my car which won't polish out where I didn't notice a bit of bird poop and it has eaten into the paintwork badly.
What's a porter cable? Is that one of those big buffer things?
Probably an Essex bird lost, A little brasso or T cut could take it away
Brasso??! Seriously?? Ok, joking aside...if you say so, I trust you implicitly Television.
Yep, as Malcolm, soak cloth/tissue in warm water and let sit on the poo. Do NOT rub, it will scratch the paintwork.
Unfortunately I learnt this to my cost on my BMW 330i I had last year. Went out with the damp kitchen roll to leave it on the dropping to soak, got distracted by something and absent mindedly just wiped it straight off. Result - 3 inch scratch across the middle of the bonnet, even T Cut couldn't get rid of it.
On another (similar) subject, anyone have a method for removing unwanted white paint splats from my nice green paintwork? I think my wife must have driven over some wet white lines which then flicked up both sides of the car - is there any way to get rid without damaging the paint I want to keep?
Haha, you're meant to use it.....dunno if you realised!
