pbrennan10
- Sep 6, 2004
Anyone had any bad experiences going cheap with clear corners?
The correct description for the oem corner indicator is "colourless" rather than "clear" as they are slightly frosted.pbrennan10 said:Thought clear and crystal were same...
Crystal better?
Shude said:The correct description for the oem corner indicator is "colourless" rather than "clear" as they are slightly frosted.
The "crystal" ones are clear.
Sadly these make the headlamps look rubbish, so...
The glass on HID lamps is still marked because the lens is used to alter the beam. I think it's no more clear than the halogens, BUT it does have a different reflector which is a bit more chrome-like than the halos.McGreggor said:I have a pair on order! I take it they'll look better with HID lights as they're a bit clearer than the halogen lights?
