I have a E220 avantgarde w211 facelift model 170bhp, I don't know if this is a problem or not but seems to be very random. When the climate control is on without air conditioning on the idle increases to about 850 rpm then sometimes drops back to 750 rpm but mainly stays at about 850 rpm. If I turn the climate control off the engine drops back to 750 rpm and stays there but as soon as the climate control is turned back on it's back up to 850 rpm again with the air con off. Also if you turn the temperature down to 18 or below it drops the rpm back to 750 but as soon as you go above 18 it's back up to 850 rpm. If I turn off the climate control it drops back to 750 rpm and then turn on all the electrics, rear heater etc it still stays at 750 rpm which to me suggests it's definately something to do with the climate control.
I have had it around to my local motor engineers and even they are stumped by this and haven't got a clue why it is doing it.
Any help or suggestions would be appreciated.
