Automac29
- May 29, 2012
- Location
- Dorset
- A207 E-Class E220 BlueTec AMG-line Cabriolet 2015 auto
CLK 350 (W209) Convertible, 2006, Following windscreen replacement the vehicle’s ‘climate control’ (Thermatic) malfunctions when the ‘auto’ setting is selected (and once engine coolant is heated) - it:
- increases cabin fan-speed to ‘quite high’ within a few moments after selecting ‘auto’ with no control of fan speed (except ‘off’ when ‘0’ is selected on rotary dial).
- pumps out hot air into cabin (with no apparent control of temperature via the usual rotary temperature dials).
- Turning off ‘auto’ stops high fan speed but cabin air temperature is not controlled and stays hot - even when manually using the rotary temperature dials.
I suspect possible malfunction of one of the 2 cabin temperature sensors… The sensor that I suspect is in this light cluster which (of course) has to be purchased as a complete unit - i.e. the sensor is not replaceable by itself... (photo attached).
At the same time, my Indie garage checked for fault codes (he cleared them all only last week) and suddenly 'found' 4 pages of 'faults' showing of which only the seat heater was 'real' and needed to be reset. The battery was not disconnected during the windscreen change.
Please, if any 'guru' can throw any light on this most annoying problem I would be grateful.
