Climate Control
Merc-C180K
I've got the Air Con with the knobs on either side to control the passenger and drivers side.
Is there anyway to replace this with a climate control module which you can set to a certain temperature?
I can never seem to get the temp right in the car :(
What year is your car ?
Do a search - this topic is being discussed at the moment .. the short answer is yes, it's possible, but may not give you full functionality - there's no guarantee it will work, and additional parts may be needed for it to work properly.
S.
I wasn't sure if they were on about the same thing as I meant - oops!
Its a 2003.
I understand from other forums, that it is only a matter of changing the control unit, and I do know people that have done it
Sorry I've done it already and Sym is dead right. If you do search you'll fine the threads detailing the problems getting full funcionality and also the amount of coding required. It can be a a plug and play mod but it can also be a plug and throw it away mod.
