Spinal
Uxbridge
G350, Duster, S320, 900ss and a few more
Well, it's that time of the year... the time I dream of stupid summer projects!
This year, I was thinking... I could build a climbing wall at home!
Problem is, the only brick wall that is high enough is on the front of the house, and while I could drill holes in it and countersink expansion nuts so that when I wanted to climb I could put holds up... this isn't ideal as I would need to remove the holds every time I finished climbing (having a route up to a window isn't ideal!)
The rear of the house doesn't have a 2-storey wall, the first floor of the house has clay-roofing-tiles and slopes down to the ground level...
So my thought was to put a piece of marine plywood over the tiles, somehow anchor it to the roof and then anchor the holds to that... the belay anchor at the top could be set to the actual house which should be strong enough...
My question is this though...
- Could my nehibors complain that there is a climbing wall on the house? (which is at the rear and not visible from the road?)
- Would the clay tiles get damaged by having the marine plywood on top of them?
- any ideas?
M.
D
Deleted member 37751
Guest
Isn't this just making it easier for burglars to get in?
OP
OP
Spinal
Spinal
Uxbridge
The rear (the side where I want this) doesn't have any windows :) The other sides of the roof have only 1 window, and this is already easily accessible from the rear (sloped roof). This window doesn't open.
Side 1: Flat wall, 1 opening window. No easy access without holds... hence, why I want to put it on sides 2 or 4...
Side 2: Sloped roof halfway, no windows
Side 3: Sloped roof halfway, 1 window. No wall planned here.
Side 4: Sloped roof halfway, no windows
Would I need planning permission?
Sp!ke
Administrator
West London
SL500 & The Fart Car
plenty of trees in the park - go climb some of them.
Sorry but I think your idea is ridiculous - of course it will upset the neighbours.
dulayj
Near Winchester
A 210/Volvo XC90
if you are truly serious about this i would definitely check with council-otherwise it will all end in tears when objections fly in!
OP
OP
Spinal
Spinal
Uxbridge
Who in the council would I need to contact? Planning officer?
OP
OP
Spinal
Spinal
Uxbridge
I climb regularly (3-4 times a week) at several walls... (Archway, Castle, Westway, and Brunel)....
Issue is...
Brunel is too small (house sized!) and expensive
Castle is very far
Archway is bouldering only and far
Westway is good, but takes 30-40 minutes to get to.... which means for a quick hour long session, it's not the best...
I've emailed my council... let's see what they say... I was thinking, if the roof tiles would get damaged by the plywood, I could build a floating structure that rested "over" the tiles without touching them...
M.
OP
OP
Spinal
Spinal
Uxbridge
Trees are much more fun.
That's how I got into IT... long story, but in short:
-fell out of a tree, damaged my arm very seriously
-spent 2 years in hospital with Volkmann's syndrome. 85% chance of having my arm amputated at one point
-got told to try to use my fingers to type/play video-games as my arm was paralised... so I got my first console and PC...
I still like climbing trees... but I quite like the feel of a safety harness and a rope nowadays!
M.
finisterre
Buxton
Vito, Z4, 530i touring
A mate has one in his garage. It slopes up along the ceiling and down the other side.
OP
OP
Spinal
Spinal
Uxbridge
I did think of the garage/loft wall... but that's back to a bouldering cave and not a sport/top-rope wall...
How long do councils normally take to respond?
M.
rf065
Grossbritannien
SLC300 - C250d Estate 4 Matic & Z900rs
M.
Can take some time usually, but in your case they will most likely pass the details to the nearest asylum, watch out for the men in white coats paying a visit and have an overnight bag packed in case. ;)
Russ
Dieselman
Banned
Peugeot 403 Convertible
Cut some steps into the lawn and get horrendously pi55ed, you will think you are climbing Everest.
nick mercedes
far far away
Ford Expedition
Why stop there, why not install a water slide too.
I'm sure your neighbours and the council won't mind.
Tan
Woodford Green
W140 S-Class, Porsche Cayenne and Porsche Boxster
Issue is...
M.
Surely if this one is too small, would your home one, also house sized, be too small as well and if you climb one at home frequently won't you find it less of a challenge and thus get bored of it?
Regards
Tan
