lyrobertson
- Aug 5, 2009
Hello
First post so please bear with me!
I have a 55 plate CLK 200K, 44K miles. A few months ago my engine management light came on, was going up hill, about 4000rpm, then loss of power and the car drove like a pig. Was all fine again after i switched the engine off. Happened a couple of other times.
Went to Merc dealer who told me that it was likely to be 'sticky' values and would need total engine stripped down (not cheap!). Fault code was misfire on cylinder 2.
He swapped over cylinder 2 and 3 just to check it wasn't anything else.
Car then ran fine for 3 months, no problems, high revs, uphill, flats, perfect.
Then fault back again yesterday.....
I just can't understand why if it was a mechanical fault it went away for 3 months??
So we have bought a replacement coil pack to try that, but we don't know which cylinder is number 3 (where hopefully a faulty coil pack is now sitting and not an expensive new engine) Is is just as simple as the third one from the front, or is it in reference to the firing order?
Any help or advise would be gratefully received.
Many thanks
Lynne
Many thanks
Lynne
