Hi everybody,
Just joined the forum and hoping for a bit of advice please.
My dad has just bought and collected a 51 plate CLK 230k Coupe. All seems ok apart from a bit of a wierdy on the clutch.
I test drove it for him at weekend and all was fine.
Today he tells me that after driving around all day in it the clutch seems to play up at times as follows.......
When driving (any gear) and resting foot on clutch pedal (as most people do) - after a certain time (not constant) the pedal will "drop" about 2 inches!!!
It still works fine and comes back to full feeling after a couple of presses. The biting point seems to be the same as well.
He also said that on one occasion only the pedal stuck and he needed to lift it back up with his toe. It did'nt do this when I tried it but did seem to drop frequently - not at first but more and more as I drove it further.
Just wondering if anyone has come across this before? This is the first Merc any of us have owned so have no other experience.
I am technical and know how things work but not sure of the layout of the clutch system on this CLK.
I believe it to be a hydraulic system so;-
1) Can it be bled?
2) Is the slave cylinder external to the bellhousing?
3) If so is it easily accessable?
4) Anything else it might be?
My initial thoughts are poor fluid - although the brake fluid should have been changed as part of the service I doubt very much they will have bled the clutch through as well so we have potentially 5 year old fluid in it - getting hot - breaking down??
does this sound feasable?
Cheers all
1) Can it be bled?
Cheers all
