Clk 500
Discussion in 'General Discussion' started by mostin, Jun 6, 2011.
  1. mostin
    mostin Member
    56
    May 10, 2011
    Taunton
    Car:
    CLK 500
    Hi all, i bought a 2002 clk 500, its all fine and loaded with everything and drives like a new car.
    Only a few things i'm not sure of,
    the keyless go doesnt seem to work on the drivers side, it opens on the passeger side and boot. Is there a setting somewhere or could it be a fault (handle switch maybe?)
    When i close the sunroof, it closes then goes back halfway. Dont know how it goes back, i just keep trying and it closes when i hold 'tilt' after a while.
    I have a button on the dash for the rear headrests, doesnt seem to do anything, is it there to be wired in another time?
    Thanks for reading
  2. dokalj
    dokalj Hardcore MB Enthusiast
    1,526
    Feb 23, 2009
    Star Diagnostics would be my first port of call if I can not see anything obvious.
  3. OP
    OP
    mostin
    mostin Member
    56
    May 10, 2011
    Taunton
    Car:
    CLK 500
    where do i find one of those? Main dealer? If so how much would it cost me
  4. moonloops
    moonloops MB Club Veteran
    5,053
    Oct 8, 2009
    :Location : Location
    Car:
    W204 C350 CDI AMG Sport
    Star diags at main dealer and good independent merc specialists. With regards sunroof have you done a reset on it ?
  5. OP
    OP
    mostin
    mostin Member
    56
    May 10, 2011
    Taunton
    Car:
    CLK 500
    If i read the manual right, close and hold tilt for a second. Tried that and still the same
  6. moonloops
    5,053
    Oct 8, 2009
    Car:
    I can't remember the exact sequence but it is something like this:
    1. Engine off and key at position 2
    2. Slide sunroof all the way back and hold the switch for 10 seconds after it has slid all the way back.
    3. Slide sunroof all the way foward and hold the switch for 10 seconds after it has slid all the way forward.
    4. Ignition off
  7. asad7860
    asad7860 Hardcore MB Enthusiast
    110
    Apr 29, 2008
    UK
    Car:
    E55 W211
    Your dirvers side keyless go module is faulty, this will need replacment. (I had this on my E55) - very common because the driver side gets all the use
    As for the sunroof, I am not sure, perhaps the runners need a clean and the system needs to be reset?
  8. OP
    OP
    mostin
    mostin Member
    56
    May 10, 2011
    Taunton
    Car:
    CLK 500
    moonloops, tried that and when i tried to move forward it stopped and went back halfway again. Gonna have to go to mb anyway so might as well get it looked at.
    Thanks for the help guys, loving this car. Still in the honeymoon period so lots of cleaning and posing :)
  9. OP
    OP
    mostin
    mostin Member
    56
    May 10, 2011
    Taunton
    Car:
    CLK 500
    Took the car to a merc specialist today,
    It went on a star diagnostic and they reset the sunroof, rear headrests work now and they will take another look at keylees entry when i bring both keys. All for £35, result :)
    Gonna stick to them cos the main dealers £118+vat labour charge per hour scared me off!!
  10. moonloops
    5,053
    Oct 8, 2009
    Car:
    Bargain, if your independent garage continues to give good service give them a mention on here. £35 is a bargain.
  11. OP
    OP
    mostin
    mostin Member
    56
    May 10, 2011
    Taunton
    Car:
    CLK 500
    I was here that i heard about them! Cornerstone garage, Ilton, Somerset.
    This forum is helping loads already :)
Tags:
Share This Page
