Dand
- May 9, 2008
- C208 230K
Hi there, I hope all are well. Its just a quick one wondering if anyone has any ideas bout what could be wrong with my 2000 (facelift) CLK 230.
Ive been having a bit of trouble with the central locking where the key is working intermittently. It has no trouble starting the car. Sometimes it will open the car no problem and when i come to lock it after my journey the key goes dead and wont lock the car. Some times it helps if i put the key in the ignition and then take it out again or switch the C,L on and off from in the car and then try the key again. Other times it wont let me in so i have to use the manual key to open the car which sets the alarm off.
Initially i thought it could be down to not being used much over the past two months as ive been working from home and the car was stranded on the drive over the snowy period and christmas but its had a few runs since and isnt bad bad but is still playin up a bit. I dont know if it has anything to do with it but thought it might be worth mentioning that both keys are effected but some times alternately work and are stored with the keys to my families cars. the other thing is a few months ago i had some paint work done as the car had been vandalized and the body control unit had been opened up and not resealed properly which lead to a leak in it.
Any ideas is much appreciated.
Cheers guys,
Dan.
Cheers guys,
Dan.
