Thanks Ash, but I'm not sure that I am - I have tried numerous LED bulbs, from very expensive to unbelievably cheap, and have now concluded that, it is not worth the bother to try to replace monitored bulbs with LED ones - best I got was perhaps six months before the error popped up (and it was the cheapest ones, COB type). The worst were supposedly error-free and pricey, turn signal ones, that immediately resulted in very rapid flashing, and were removed within an hour.
DIY solutions, like adding a resistor (which is what those so-called "CANbus compatible" LED are anyway), run very hot and I feel just too much of a safety compromise, plus they eventually come up with error anyway, and have a very limited lifespan.
Internal lights, on the other hand, are not monitored, and work brilliantly with cheap, cool (as in low temperature, due to no resistors added) COB bulbs.
Same for DIY aftermarket DRLs, as in my thread linked above - work perfectly and flexible enough to be adapted to an individual taste.
If OP is absolutely set on modifying fog lights to LED, whilst retaining fog light function, rather than adding a separate set of LED DRLs - there are more expensive options: HELA fog lights, about £200 or so IIRC, or Brabus fog lights, around £500, give or take. I didn't look into these options closely enough to comment though.
