CLK Mileage Display - new model W209
saorbust
CLS350CDI
Hi all,
Quick Question to new CLK owners. We've had ours for about 2000 miles now.
Thing is, whenever you engage speedtronic or the cruise control - the digital display 'speed' is not the same as the speedo needle reading. EG, when the speed needle is on the 80 figure exactly - and you engage cruise control, the cruise control reports 84 mph or therabouts.
Normally I wouldn't worry too much, but given the amount of speed cameras etc in this country I'd like to know how fast I'm actually going !
I asked the dealer to calibrate it when they fixed a problem - they said they had, but I don't think so. Any ideas ? Any one else tried this ?
RichardM
Essex
2011 CLS350 CDI
I don't have a CLK, but just thought I'd mention mine is always identical, the speedo, the digital speed display and the cruise control setting.
fuzzer
Glasgow
F25 X3 20d SE
Mine does the same. I think the cruise is more accurate than the speedo .
When ive got my GPS setup the speed on the GPS matches the speed displayed on the speedo when im using the limiter.
LEt me know it its a fault , but , ive just taken it as read. :S
OP
OP
saorbust
saorbust
CLS350CDI
Good to know I'm not alone !! Okay now how to fix it...
mayoga
CLK 320 & Elise LB RT
Pretty sure my Cruise and Speedo read the same although I'll check on the way home tonight :)
Gav.
mayoga
Checked on the way home and my reads correct :)
Gav.
clk270
Now Brecon Beacons National Park
Was W203 270CDI A'garde, Was CLK270CDi A'garde, Current Porsche BoxsterS, Mini SDAll4
I've noticed mines not always correct either.
Put cruise on 32mph to get needle on 30 marker
Put cruise on 72 to get 70 on the speedo needle
In between its a little hit and miss - some readings are correct other are out by 3-4mph.
Haven't tried it against the gps on the Navman as yet, but be grateful you haven't got a Nissan - afew weeks ago I had an Almera hire car and I couldn't figure out why so mnuch traffic was passing me on the motorways and why it took forever to catch HGVs in the distance - -then looked at the gps to find 70mph was 63mph by the gps - needed to put 78 on the speedo to get 70mph by the gps !!!.
Whilst i'd like to believe the gps, its too late when the envelope drops through the letter box ! :confused:
mayoga
Jason,
Yep CLK320 (W209) only 8 months old :)
Gav.
OP
OP
saorbust
saorbust
CLS350CDI
Glad I'm not alone - I will attempt to rectify via the dealer and let you know how I get on.
fuzzer
Glasgow
F25 X3 20d SE
Thanks , let us know how you get on . I just put up with it TBH.
I must admit the cluster on my 202 was dead on :S
Aswall
South Yorkshire
CLS 350
I have a 209 and my digital and analogue speedo readouts are always different, and both are wrong :rolleyes:
At a steady 70 on analogue readout, digital readout is 72/73 and GPS is 68. Doesn't bother me as I've never known a digital speedo on a a car be accurate and I only use my GPS anyway. The speedo on the Nissan 350Z is particularly comical and seems to read 9mph over at 80mph! Doesn't seem to worth the aggro of getting it changed IMHO
Cheers
Andy
mayoga
Not had time to read the owners manual, how do I check the GPS speed?
Gav.
Aswall
South Yorkshire
CLS 350
Buy a Road Pilot :D
I assume you mean the GPS speed relayed to your COMAND, sorry can't help as haven't got it. Would probably tell me I was doing 570mph through the Peruvian jungle knowing my car!
Cheers
Andy
clk270
Been out logging speeds tonight in my CLK270
As follows:-
Speedo / Cruise Display / gps (by Navman/iPaQ)
30 30 27
40 40 38
50 51 49
60 61 58
70 71 69
80 82 78
Using speed limiter :-
set limiter at 50, speedo needle 50 and gps 47
set limiter at 70, speedo needle at 70 and gps 68.
Conclusions:-
1. speedo is pretty accurate,
2. cruise readout gives highest reading
3. both are higher than your actual speed (assuming gps to be accurate) .
4. limiter function probably uses the same signal as the cruise control
but most importantly,
5. Using the speedo needle will keep you out of trouble
Not sure whether this is still the case but speedo needles had not to under read, but could over read over by up to 10%, ie an indicated 70 could not be over 70mph actual, but could be as low as 63mph actual.
Also bear in mind that the speedo / cruise signal will depend on tyre sizes and wear rates. Whilst the rolling circumference of 16 / 17 / 18 inch factory wheel options are fairly close they are not identical. This will give some slight variations.
And lastly, new tyres have a rolling cirumference of 40 or so millimetres more than when they are at the wear indicators (equivalent to 2% or 1mph @ 50mph).
mayoga
I guess with my 18" AMGs this make my speedo/cruise reading spot on :bannana: :bannana: :bannana: :bannana: :bannana:
Gav.
clk270
These are the rolling circumferences of the factory options:-
18 inch
225/40/18 2003mm
255/35/18 1998mm
17inch
225/45/17 1994mm
245/40/17 1973mm
16 inch
205/55/16 1986mm
225/50/16 1984mm
So between the lowest and the highest is 1.5%
Given that the stock wheel is 16 inches then the AMGs could be out by 0.9% (ie it ain't worth worrying about !)
mayoga
Unless the Donkeys @ MB calibrated it using the AMGs :)
Gav.
OP
OP
saorbust
saorbust
CLS350CDI
Wow great info thanks. I will check tomorrow with my Garmin GPS device !!
With wheel size check the calibration option in the COMAND system.
Cheers everyone - I guess over reading on the speedo needle is better than under reading !
mayoga
As CLK mentioned this is the law as speedos HAVE to over read.
Checkout www.pistonheads.com.
Gav.
