CLK Remote Window Closure
Discussion in 'Interior' started by br0ke, Sep 12, 2008.
  1. br0ke
    br0ke Active Member
    338
    Sep 10, 2008
    I picked up a 2005 CLK a few days ago and am still getting used to it.
    I can open all 4 windows with the remote by pressing the open button, but I cannot close the windows from the remote.
    Is there a reset function for the windows like there appears to be for the seats or could there be a small fault with it.
    Any suggestions are much appreciated.
  2. rf065
    rf065 MB Enthusiast
    4,055
    Jun 8, 2007
    Grossbritannien
    Car:
    SLC300 - C250d Estate 4 Matic & Z900rs
    You need to make sure you are pointing directly at the black square in the drivers door handle or it won't work.
    If you can put the windows down but not up, it shows the sensor is working, probably a fault with the remote?
    Russ
  3. dickchailey
    dickchailey Active Member
    124
    Dec 5, 2006
    East Sussex UK
    Car:
    SL500 R129 1999
    Try pressing once to lock the car and then press again and hold pressed untill the windows and roof close. Works like that for me.
  4. OP
    OP
    br0ke
    br0ke Active Member
    338
    Sep 10, 2008
    And it gets even more confusing.
    My key allows all the windows to open but won't close them and the wife's key will close all the windows but not open them.
    A software reset might clear its head.
    It's not an important issue but very strange.
  5. rf065
    rf065 MB Enthusiast
    4,055
    Jun 8, 2007
    Grossbritannien
    Car:
    I'm sure there is a re set procedure for the windows, but cannot remember exactly.
    Only other thing is to change the batteries in the remotes. One of mine would lock the car no problem, but refused to open the car, new battery solved it.
    Russ
  6. OP
    OP
    br0ke
    br0ke Active Member
    338
    Sep 10, 2008
    Success. Battery change did the trick.
    Now it works I'll probably never use it but thanks for the solution.
Share This Page
