mcbeathclk
- Jan 26, 2017
- W208 CLK Convertible
My roof has stopped closing. Opens fine using the switch on the console. But when you try to close it nothing happens. The switch lights up to open the roof but doesn't light up the you try to close it. I can close it manually so am not stuck. Could it be a switch or a relay problem?
The problem started when I left the roof part closed to lubricate the hinges and pivot points on the frame.
Car is a 2001 230 Compressor W208
Bye, John
Bye, John
