clk w208 heater fuse
Big Mark
bexleyheath kent
CLK 230 CONVERTIBLE
Hi can anyone tell me where the heater blower fuse is located, the heater stopped working and wanted to check the fuse first before looking at the heater blower.
thanks
Has it stopped on all speeds?
They suffer with the regulator pack on the bottom of the motor failing, if so will usually still work in full speed
Fuse would probably be in engine bay fuse box on right handside, usually gave a fuse chart on inside of lid, also check in the end if the dash in drivers side
yes it has stopped on all speeds, its been playing up for the last 2 weeks switch it on and started then stopped then after a wile it would come on and stay on.
