CLK W209 Advice Needed!
speedevilus
Hi All,
I have a 2003 CLK W209 and have run cables to the boot for a Twin Subwoofer and AMP. However, I am just wondering if anyone knows of a thick Power cable that may exist in the boot to power the amp.
There is a few live wires in the boot and also the fuse box but none that is thick or powerful enough to handle the bass.
Any ideas?
Failing that I would need to run a cable from Battery direct to the boot which is not a problem but just means I have to take carpets etc. off again.
Cheers
Andy
Ideally you will need to run a proper rated power supply lead - a Stinger would be favorite. ;)
