CLK w209 Convertible - roof problem
KratekPL
CLK 320
I have a problem with the roof, when I press the button to raise the roof of the pump can be heard humming, windows go down, the roof in front of the car carries about 1 inch and its all. Closing works ok.
I noticed a fluid leak around the front of the roof, the amount of fluid has dropped below the minimum and the roof overnight stop to open. Refill the fluid did not cause the effect. Do I have to let air out of the system? A leaking cylinder already bought and I need to replace it. What should I do after replacing? I will be grateful for your response...
