dddooommm
MBCLUB members-
This is my first well over due post,
Really struggling for help & can't find any specific info on this!
SRS system is my specialty- Please help with my aftermarket audio electrics.
My overall outcome is to fit my aftermarket Pioneer headunit that was previously working in my old CLK W209 2002. Not bothered about steering wheel user interface at this moment.
I'm using the same block wire ISO adapter kit but the wires seem different this time! Not so much plug & play this time. Please help!
***Things i'm struggling with***
1)Do I need just the 12v ignition live or the earth off of this too?
2)Which wire do I replace with the new extra 12v cigarette lighter wire?
3)In my photo with the 4 block connectors- What are the left two for? (steering wheel buttons?)
4)What are these wires from the main audio power block ? (see pictures)
-Brown wire? (Ground)
-Black wire?
-Red/Blue wire(Constant 12v?)
-Yellow/black wire(Mute?)
-green/black wire
What I need to do with your help is to understand what the factory Mercedes audio wires do so I can manually block connect them up to my Pioneer ISO cable harness wires.
I'd have thought the wiring would be the same for c class w203 or the old CLK but no luck.
Yes the "Morons guide to installing an aftermarket headunit" is an amazing post but it doesnt cover the issues i've found.
Facts & what i've tried:
>I know I haven't got an oem amp
>I've tapped an extra wire into the cigg lighter wires.
>I've tried plugging in
>I'm getting postivie readings with a multi-meter
>CLK w209 2003 Elegance cdi U.K. Spec.
>I've blown a few fuses experimenting
>I've put aftermarket head units in before in a c class & clk
Thank-you all in advance, Any advise or experience is appreciated. Just to confirm im lucky enough not to have a factory amp.
DDDOOOMMM
White CLK w209 CDI Full AMG Facelift+ Red Leathers <3
-Black wire?
-green/black wire
DDDOOOMMM
