clk w209 specs identification help needed
astamir
london
w208 silver clk55
Hello everyone
Ive got clk500 w209 model that has been damaged previously from what I can see it has or should have xenon headlights, but it has some HID bulbs fitted very badly with wires messed up.
I am planing to put new headlights and don't know what headlights it should be.\anyone can help if I provide the reg please?
thanks
Run the VIN through one of the many online VIN checkers
VIN checker is the easiest way. You could also check the wiring to see if it has the fitting for a halogen bulb (H7 etc) with an adaptor for the HID kit.
Does the car have the thumbwheel adjuster for the headlamp level by the lighting switch on the dashboard?
If yes, then it was originally fitted with halogen lamps.
Bi-xenons would be self-levelling, so, no adjuster .. BUT some high spec W209 came with self levelling suspension, sooo...
VIN checker for confirmation.
