- Jan 31, 2016
- Location
- Fleet, Hampshire
- 2008 CLK 350 Sport Cab and 2021 BMW 520i M Sport Saloon
Hi chaps,
I've been rooting around the interweb and on this forum for an easy to understand method to adjust the windows on my 2008 (A209) CLK Convertible.
In a nutshell, the windows rattle on both sides. The cause is clear. The rattle comes from the front window rattling against the rubber seal / weather strip which is attached to the rear window. It is a not a squeak that can be fixed with silicon lubricant - it is an actual "flapping" rattle. Upon investigation the rear windows in particular seem to have a lot of lateral / horizontal movement (i.e. they feel loose). Everything seems OK in terms of where they sit against the roof and seals and in relation to the front doors but they are not rigidly sat in place laterally. So every time you go over a bump, they bounce in towards the cabin and the rubber seal bounces back against the front window and a rattle is heard. It's as if they should be braced against something within the rear quarter and it's come loose.
I believe you can adjust the preload on the front windows which would enable me to angle the front windows in further and hence create more pressure against the rears (remove the grommets under the doors and adjust etc). I think this could ease the issue, but before I dive in I wanted to ask if anyone has a definitive way to tackle the issue. My gut feel is that I really need to adjust the rear windows for lateral looseness and I don't know how you get at the adjusting screws for the rears as clearly there is no door to open and no grommets to remove and reveal torque screws. I assume I may have to remove the interior leather side panel...
Anyone got any ideas as to what is wrong with it?
Thanks in advance!
Ed
Thanks in advance!
Ed
