nadeem
- Jul 22, 2007
- E320 CDI Avantgarde 02
I've been helping my brother with his car, Clk320 CDI 2009 with 101k miles. It's currently in limp mode with the following error codes;
2552-004 check component M16/6 throttle valve actuator signal line is interrupted
2372-001 control throttle valve the throttle valve is jamming or is stiff
I completed a live actuation test on the valve no change in value and also tested the preasure sensor which is functioning. I replaced the valve with a brand new bosch and recalibrated. Unfortunately still in limp mode with the above errors. When I clear the codes, for the first 5 seconds I can hear the valve moving but then stops with the same error codes again. I assume it could be the wiring to the valve maybe then?
Any help appreciated.
Cheers
Cheers
