I have just bought a CLK320 Cabriolet (Year 2000). I have a problem with the softop which stops while opening, and would like advice please.
It stops just before the very front section starts to tilt vertically. If I "help" it up by pushing gently, then the opening continues fine.
I have found a broken cable, which I assume is the cause of the problem. It is a cable on the right hand side (there is a similar cable, unbroken, on the LHS) which emerges from a tube near the front of the roof, and travels to the first transverse rib. It should go through a hole in this rib, and be secured by a metal "knob" on the end of the cable - to stop it pulling through the hole.
The problem is the knob has broken off, meaning the cable now is loose, and obviously doesn't do whatever it was supposed to.
So, two questions please:
1. Can anyone confirm that this cable could be the cause of my problem, or perhaps it is the result of some other (adjustment?) problem?
2. Does anyone know how to replace this cable (assuming I can by the part?
Thanks very much.
Thanks very much.
