Hey guys!
So I've got my lovely car for over 2 years and done loads of work but one thing still remains unsolved. Since I bought the car I've got a leak between somewhere between engine and transmission probably from the main rear seal although it was already changed twice (original one from dealership) and the problem after a month or less comes back. The leak is not a bad one, I don't leave huge spots on street but you can definitely see how wet is the connection or rather the area around and when it's hot outside during summer You can smell the oil once the engine gets hot and that's irritating.
I've been asking around about that issue and I was told to check the oil pressure in engine, funny enough I you may know there is no indicator in this engine to tell you anything about that so if you are about to blow your engine it will show nothing at all. Anyway is it possible that too high pressure can make the seal move and make the leak come back again?
I've done the measurement yesterday and
found that the correct should be 3.03bar although I'm not sure on what rpms. According to the video it seems that it may a bit to high in my understanding unless I'm wrong but anyway the question is, can it that be the reason why I see the leak?
Any other ideas what can cause that?
I include video of the measurement.
Edit: unfortunately I can't even after packing it to.zip file is to large
maybe that way it will work
