financenick
- Nov 14, 2013
- CLK55 Cabrio
financenick said:Cold air feed fitted
Cooler air is more dense and equals lower engine temps and extra horsepower, does not matter how thin it is, if it reflects then it's good.. Simple test was earlier when sitting in traffic for an hour we pulled over and grabbed the air box off and it was not even warm to touch underneath, it works....
For all the people having a good old laugh about some "tin foil" blah blah blah, just because it didn't cost £2k and need to be "installed" by a specialist don't mean it does not work. This mod is a proven way to reduce engine heat rising "up" through the airbox.
Here is the original thread with Dyno results and 1/4 times.
Original Thread CLK and E 55 Performance tip - MBWorld.org Forums
To the original post starter, good job mate, looks nicely done under the box.
Howard said:Wow , you're aggressive aren't you ?
Who's having a laugh about it ? If you mean kowalski , i'm sure you are aware that he isn't uk based , and hence his english isn't always quite correct. I'm sure he wasn't having a pop , but anyway , i'm sure financenick appreciates your support.
What i like about it is that the OP took the time to measure the temperature before fitting it , because as we all know , the science proves the point.
To the OP , Could you take a temperature reading with it fitted please , so we can see just how much it drops the temperature from the 183 ( C or F )?
