High-Lo
- Sep 7, 2004
- Location
- Kent
- 2013 X166 Mercedes GL350, Porsche 911 Carrera 4 Cabriolet, Porsche 968 Cabriolet
Help! My clock in the instrument cluster has developed a fault whereby the clock resets to 0:00 when the car is started. The odometer or trip recorder is not affected though and retains the last figure as normal. It is only the clock which resets.
Strange thing is that when the key is turned to position 1 or 2 the clock is still showing the correct time (or holding the time it last had before the engine was switched off). It is only when the car is started again that the clock resets to 0:00 again.
No other settings are reset i.e settings on car stereo, etc. It has always been fine until this evening.
Could I have a faulty instrument cluster?
Thanks in advance,
Steve
Thanks in advance,
Steve
