Cls 350 Steering wheel
Neeero
Ipswich
Mercedes CLS350 cdi
Hi all 😉 my Cls 350 steering wheel gone hard to turn,does anybody knows why?
No power assistance or you have two flat front tyres.
You either have no fluid in your steering system , a faulty PS pump , the drive belt for the PS pump has came off or has lost its tension or there is no air in your tyres.
K
K
Thnks, all fine apart from faulty ps pum,how to check it if it has a fault?
If it is turning via the belt and the system has plenty of fluid and it is still not working it is possibly knackered internally , which means potential replacement - unfortunately.
K
I have lost power steering overseas, going slowly around a corner and suddenly the steering wheel became stiff and hard to turn. finally found someone to install the steering pump.
So far I have changed;
  1. Hydraulic pump ( MEYLE )
  2. Steering Proportioning Valve (BOSCH) - Solenoid that seat between steering rack and column.
And still on stationary / idle or very low speed the steering wheel turns are way too stiff - really hard to turn. At speed or engine raves it feels almost alright but still somehow firm steering. ( Not as it used to be before the pump failure)
Would someone have an idea as to how it can fixed ? or what to check may be a FUSE some hidden place, I have checked high & low and cannot find as to what may cause it. I have scanned with MP iCarsoft (V2.10) scanner -still no success.
Mercedes CLS 350 CDI ( 2010 model diesel)
VIN: WDD2193222A169248
Thanks a LOT !
Mykhailo
