I also would recommend MSL, Acid in my experience will always go that extra mile for his clients, and can supply or do anything and above that the other companies mentioned here, and given OP is Glasgow based, got to be MSL, well worth the trip.
If southern based, PCS is there to do these things also.
Kleemann from 10 years ago and now differ in quality. Their headers are more affordable now. Even though they fit okay when new (after some hammer time as they all are LHD), my second pair has warped after a while. You have to cut the bridges between the inlets on the headerss as a fix. Some other Kleemann headers I've seen have separate inlets, so I'd recommend those if you're in the market for a set.
Hei Alx
Meaning to say that if I have LHD car kleemann will not warp or they will eventually?!
Nothing to do with LHD - only mentioned as thought you were local. If the inlets are bridged, they will lift and leak. The problem is not specific to Kleemann or Mercedes headers - the design is flawed.
Here's the example of bridged headers:
