CLS 55 w219 window drop
Gbrowncls55
Surrey
CLS500 4.7TT 2012,, SL350 09, 996 cab, all current. Gone :CLS 55 E500 W211, 2x M5s and too many 911s
My CLS 55 has frameless windows as they all have. Normally when I open the door the window drops a little and then rises when the door is closed. Today I got out of the car and the window dropped as usual but when I closed the door it did not rise. And it continues to be like this. I can close the window by using the door window switch but of course when I open the door it drops and then doesn't rise when I close it. So the only way to lock the car with the window closed is to get out with the key in the ignition , close the door, go round to the passenger door, get in ,close the drivers window manually remove the key and exit using the passenger door and lock the car (it has keyless go). All the other three doors/windows are working normally its just the drivers door that drops but wont rise when door is closed. Any ideas?
answered in you other thread on the same issue
