The Smudger
- Aug 12, 2016
- Location
- WILTSHIRE
- W211 E320CDI, W208 CLK 320, 260E W124, W219 CLS320
Hi all, got into the CLS this morning, and noticed the rear screen demister was not working. Did a quick search on here and noticed a thread that mentions/links the rear screen demister with the rear SAM. This makes sense a it will be a heavy consumer and the screen/relay/battery are in the rear.
So, went to the rear SAM and checked the fuse (f10), all OK. Now my background is a bit technical so i sort of thought the demister, being a heavy consumer (40A fuse so potentially working on a current flow of around 25-30 Amps) would be working on some heavy gauge wiring possibly 1.5-2mm on the load side of the circuit. So, removed the carpet/trim and revealed the SAM, then removed the NAV unit and swung out of the way, and unbolted the SAM.
Straight away the issue was apparent. The RED coming from the back of the SAM at F10 position was clearly burnt (see image 2448), and had overheated at some point. This of course would cause a very high resistance in that line, which must be the load side of the demister relay, which would of course cause it to not work.
I have done a temporary fix as i need to renew the connector and block, just going to call MB now and see if they list the connectors and blocks separately. They should do as the block as a part No on it?
I will report back soon.
Steve.
Steve.
