CLS W219 drivers window issues
AnthonyR84
Hamburg
W219 CLS 320 CDI (2009)
Hi all,
New owner of a CLS W219 320 CDI (2009)
I am having issues with the drivers side window not dropping when door is opened... auto up also doesn't work.
I have tried to reset as per YouTube suggested. I have also disconnected the battery and reset all windows and sunroof with no problems. However the driver side does not play the game.
Door switch works and I can manually push down the window when door is opened and the window resealed correctly on closing.
I'm in need of your knowledge and assistance.
BR,
Anthony
Are you talking about the 1 cm drop ?
A trip to the dealer then?
Thanks for the help.
Anyone clever with star should be able to sort it tbh.
Is the car aware that door is open when its opened ?
If you can hear the motor kick in when its supposed to drop and you tried to reset as stated then theres nothing to be achieved by plugging it in.
In my opinion its almost certainly wear in the mechanism or the window is loose on it.
If you look on Utube there are How To videos showing how to remove the mechanism, follow one of these to see how the window attaches to the mechanism and check yours for wear or possibly something needing tightening up fingers crossed.
It is a very common issue for the whole mechanism to fail hecne why theres a lot of info on the internet.
I was thinking 1 or 2 teeth at that point maybe missing, unless its a cable ??
Thanks for the advice guys.
