Cls w219 facelift instrument cluster removal
Discussion in 'Interior' started by kaniewsky, Mar 1, 2015.
  1. kaniewsky
    kaniewsky New Member
    11
    Jan 31, 2015
    Car:
    Mercedes CLS 350CDI (W219)
    How do I remove the instrument cluster? I know that I got to take the plastic surround out first and than undo the bolts underneath but what to do with the reset button which sticks out of the wood panel?
    Do I have to dismantle the wide wood piece of trim first to get to it?
  2. sidmon
    sidmon Hardcore MB Enthusiast
    107
    Mar 4, 2008
    No need to dismantle first. Once you have the plastic trim surround removed and the screws removed that hold the instrument cluster in place you'll just need to carefully pull on the reset knob. Make sure you have the steering column adjusted to lowest and furthest points to give you more room before you remove the battery in preparation.
  3. b1g1an
    b1g1an Hardcore MB Enthusiast
    1,513
    Dec 12, 2012
    Norfolk
    Car:
    Thug in a silk dressing gown
    If you have the battery disconnected you might just as well take the steering wheel off first.
  4. OP
    OP
    kaniewsky
    11
    Jan 31, 2015
    Car:
    Ok thank you.
Share This Page
