CLS320 HESITATION
Trouty
Ashtead
2005 CLS320
Hi Guys
My 320 has developed the slightest hesitation when going along at 30-40 mph using minimal throttle. Has anyone experienced similar?
I'm wondering if it could be the sensor in the throttle pedal itself?
That was similar to my clk, and a replacement MAF cured it.
Easy job iirc.
Check all the hoses on the induction side. I had a hose clip break and the pipe worked its way of the turbo and gave the same symptoms as you have.
I'll try all suggestions and let you know. Thanks for your input. Much appreciated!. MIKE
