[SOLD] CLS55 AMG
chris-durham
Scotland
2005 CLS55 AMG
For sale is my 2005 CLS55 AMG.
I have owned the car for around 4 years now, I bought May 2017 with 98k on clock, from previous keeper on here (Abb) who bought it Aug 2013 with 81k on clock.
We now have approx 103k on clock.
Service records:
17076, 30469, 44460, 57720, 66497, 78838, 88641, 93827.
Below is a list of some of the restorative/maintenance work carried out by Abb and latterly by me:
2013 - suspension height level sensor, front disks and pads, rear disks and pads and park brake shoes,
2014 - both front Arnott struts, CLS63 steering wheel
2015 - steering control module
2016 - SRS sensor, gearbox oil and filter
2017 - Front disks and pads
2017 - airmatic compressor, 2 rear tyres, front sus rebuild(track rod ends, bottom arms, upper balljoints, torque arms, bottom balljoints. both engine oil coolers and hoses, engine oil and filter change, rear shock.
2018 - rear subframe rebuild(subframe removed and powder coated, frame to car bushes/bolts, diff mounts and bottom bushes, rear prop uj, rear brake hoses, rear wheel bearing + hub bush, rear drop links, rear brake backplate, n/s/r diff seal + diff oil change, rear ABS ring, v-belt tensioner pulley)
2019 - service (engine oil/filter, spark plugs, air and fuel filter)
2020 - front subframe replacement and new bottom arm, supercharger pulley
There is a critical build thread in the project area showing all the gory details ;+)
The car a fairly good spec, heated/cooled front seats, heated rear seats, sunroof, alcantara headlining, elec rear blind.
I am looking for £12k and am based just north of Edinburgh.
image1 by chris pollin, on Flickr
image2 by chris pollin, on Flickr
image0 (4) by chris pollin, on Flickr
F8168D39-C4AA-4C1D-A8DA-926BB2958252 by chris pollin, on Flickr
56DE95E0-4F84-4B61-A588-AFF4DEBA2997 by chris pollin, on Flickr
08AC64D8-FED1-4CFE-B690-2E5271ACA33B by chris pollin, on Flickr
IMG_4690 by chris pollin, on Flickr
Untitled by chris pollin, on Flickr
Now reduced to £11500, if still no takers will have to stick on ebay in a couple of weeks :(:(
Have been sidetracked on some other projects for a couple of months, so decided to do a couple of jobs on the CLS.
1) aux water pump, was mysteriously loosing a little bit if coolant when engine was running which i eventually tracked down to a worn aux water pump. So thats now sorted.
2) after 4 yrs with parktronic not working, plugged it in and found it needed 2 front and 2 rear sensors. The rears could be changed on car which didnt take too long, but those front ones needed the bumper skin removing which was a fun job lol.
3) to book mot, i just checked and its out in Sept, so will get this sorted and readvertise for sale
Reduced to £10999
