Interesting, where was your battery installed?
So, did you have a spare wheel fitted in the wheel well? Before you installed the amps?Central and forward of the wheel well.
I think a couple of owners had leaks around the rear light clusters, worth a checking
Sorry, but you're wrong, tried more than one Merecedes pump, and a ford pump too, none of them have the punch required to inflate the tyre during it's initial stage of inflation, which requires the crease in the tyre to "pop" out, after that has happened, yes the 12v thing will slowly inflate to 36psi.
