Andrew W
- Oct 26, 2014
- Vw caddy
Evening , so I fitted the new window regulator
and all good but the window is not dropping
the little bit to allow the door to open or close
without doing it manually , when you touch the
door handle it should drop , I've tried the window
reset maybe not done it properly though !
does anyone know what tells the window when
to drop and go up to seal it , I know there's a
door switch next to the catch , thanks I advance
Andy .
Andy .
