brucemillar
- Nov 18, 2010
- C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
Folks
My lovely 3.5 V6 24v Pajero (yes the one that was rescued from certain death by Carat 3.6) every now and again I turn the ignition to start and I get a resounding click but nothing else. Then if I turn the key again I sometimes get a loud buzzing from the passenger side dash. I presume that the latter is the fuel relay not fully engaging as this is where it is located.
The car has:
1 new battery that is well maintained with new + / - leads and terminals.
All earth points cleaned and checked with good wiring.
1 New fuel relay - It does the same on the old relay.
1 New starter motor - fitted by Simon
The starter motor wiring and connectors (known weak spot) have been re-crimped and cleaned.
So basically I am thinking that I have almost everything I should have done to get to the bottom of this?
A suggestion is that it may well be the ignition barrel contacts where the loom plugs into the ignition barrel? I believe that these are wiper contacts that are made when the key is turned.
Before I start removing the ignition switch (this is a faff) does anybody have any other suggestions?
It will do this at random on both keys and whether the car is hot or cold. Usually removing the key and giving it a wiggle will see it start first time again. This is not proven and could just be what it is. My worry is that this is waiting fail when I am at my most vulnerable. Facing downhill against a wall or worse when Mrs M is driving.
Any suggestions?
The car has:
Any suggestions?
