Clunk from drivetrain when slowing down...any ideas ?
vijilants
London
C320CDI Sport W204 gone now C43 AMG
Hi Folks,
On my W202 C230k Auto, when slowing down to a halt or slowing down to take a speed hump, I am getting a clunk sound and it sounds like it is coming from the gearbox / propshaft area. It has that feeling as though there is some play occuring in some area.
I doesn't happen every time, but 70% of the time, especially notoceable when the car is still cold.
Any ideas ?
Will
Hardcore MB Enthusiast
Surrey
GL63 AMG / 190E 2.5-16 / Porsche 911
It's probably one of the propshaft couplings.
I had this on my old C230K, at around 80K miles.
The old coupling was well and truly shot - you could wiggle the holes in the rubber where the bolts go through about 1/2" side to side.
Basically, as the box changes down from 2nd to 1st (or maybe 3rd to 2nd), the slack in the drivertrain causes the clunk.
Get it checked out on a ramp - from memory the couplings are fairly cheap - something like £20-40.
Fitting is straightforward, just about 1/2 dozen bolts.
Will
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
Propshaft U'J's , centre bearing/mounting, differential mountings, rear subframe front mounts,worn differential, engine / gearbox mounts probably in that order.
OP
OP
vijilants
vijilants
London
Will
Front - A210 410 1115 - 100.99
Rear - A170 410 0015 - £81.96
Thats with 10% discount :eek::eek::eek:
Adam230K
German oil burner
i think the couplings are about £90, i bought them for mine (invain) and returned them
Will
Surrey
Maybe MB have increased their prices recently? I certainly don't remember paying £100!
FWIW, one of my 190s had a new propshaft coupling a few weeks back, that was about £40ish from memory for the part.
Will
Adam230K
German oil burner
Desilva, Check which joint it is, when i recieved the second hand diff, i got a free propshaft coupling. if u need it let me know.
Dieselman
Banned
Peugeot 403 Convertible
Is your car all sorted now Rage. Did you go for the same ratio diff or an upgrade.?
Adam230K
German oil burner
same ratio, and yeah its all sorted, thanks for asking.
OP
OP
vijilants
vijilants
London
Conclusion
Yep Will, you were right - turned out to be the coupling. Replaced and all OK now. :)
Rage thanks for your offer, but I decided to fit a new one.
Will
Surrey
Hi Vij,
Nice one - it should drive noticably better now when slowing down.
Out of interest, do you know which coupling it was that had gone - front or rear?
Did the part still cost £80-100ish?
Will
OP
OP
vijilants
vijilants
London
Hi Vij,
Will
Hi Will,
It was the front one and the part cost £100. Its now coming to a halt as it should.....super smooth.
Jay....I got it done by MB so didn't have to use use Euros.
Reason why MB did it is because it was covered under a warranty that I have on the car.
