BTank88
Recently been getting this EML and subsequent error code come up, intermittent possibly only on cold starts.
P2258 Secondary Air Injection System Control A Circuit High
I'd guess the auxiliary air pump is not activating intermittently causing the EML and code on cold starts.
I'd like to start with basics first, and being an intermittent fault which upon clearing will stay away for several starts, I'm suspecting a relay of some sort. Lo and behold the circuit and pump is controlled by a relay upon researching:
Just trying to chase down the part number for it so I can source a replacement.
Fuse Box Diagram Mercedes-Benz C-Class (W204; 2008-2014)
Fuse box diagram (location and assignment of electrical fuses and relays) for Mercedes-Benz C-Class (C180, C200, C220, C250, C300, C350, C63) (W204; 2008, 2009, 2010, 2011, 2012, 2013, 2014).
fuse-box.info
P | Valid for engine 156, 272, 276: Secondary air injection relay |
