Stevellew
- Dec 25, 2014
- Location
- soffryd crumlin Newport S Wales
- 53 plate ML270 inspiration
I've got a Fujitsu Siemens windows 8 will it work on this and where did you get it from thanks.
Hi there, I have used it on windows 8 (not 8.1) and I am currently using it on windows 7.
I have had to install win 7 as my other test equipment (scopes and function generators) will not run with windows 8. CDP+ did run on windows 8 though...
Just double checked, it was £90, not 80.... sorry.. I have just checked my ebay history and found the page. It is from UK supplier!!!!
2015 Universal Car Diagnostic tool , Programming Interface, Scanner (Bluetooth) | eBay
Hope this helps1
Will this rest/clear SRS lights?
Yes... I will admit that I have never done it (not needed to) but it picks up the SRS controller and will allow the SRS to be reset. If you have an ongoing fault, then the light will come back on.
It will also reset service lights as well......
Hope this helps
Hope this helps
Hi Phil, does your car have parktronic & if so can this unit see the parktronic controller.
Thanks.
Unfortunately I do not have Parktronic..... So I could not answer that question......
But, if you let me know the year and model of your vehicle, I could have a look and see if I could check that out on the software without connecting it to the car.
It does have ISS (Intelligent System Scan) which should pick up all the systems on a vehicle.....
You have to be careful with Windows Vista/7/8 and OBDII software. in most cases the drivers won't work so you have to shop around to find updated version that do. However, there are 2 possible workarounds. 1. Right click the icon for the prog and select properties, go to compatibility tab and change compatibility mode to Windows XP and select run as administrator. 2. In win 7 ultimate I downloaded Windows XP mode module which is effectively runs XP in an emulator window or full screen. This allows you to run most older software for car diagnostic on newer machines.
You can get XP mode from microsoft here
Download Windows XP Mode from Official Microsoft Download Center
Forgot to add you need virtual pc installed
Download Windows Virtual PC from Official Microsoft Download Center
