Code readers
Another +1 for Autocom/Delphi, been using mine for a while now. Just remember these are clones
Yes prefect for everything ive ever needed to do. Used it on loads of other makes and also about five different mercs. It paid for itself when the abs sensor went on my ML.
This does look very good value for money if it can do all this, does it do exactly or near enough what the star can do, for example can you do sterling angle sensor with it as that's what is going on with mine at the moment
Under Multifunction it has :
Air Suspension
AMG Drive Unit
Audio COMAND operating unit
Central Gateway
Distronic
Doors
Electrical power steering
Head unit
Headlights
Keyless Go
Multifunction Camera
Overhead control panel
Parking assistance
SAM -Rear
SAM Driver-side
Steering wheel electronics
Tailgate Control (boot lid)
trailer connection unit
So I think it would be under Steering wheel electronics which gives you SCCM(steering column module)
But cant check live data the now as wife has car till Sunday :fail
When I get car back I will check for you:thumb:
SORRY never seen your car was a ML and my laptop has powered down will check later today for you....
I used it with my existing Bluetooth ODBII reader, it found a couple of ECUs but missed the majority of them, and then it found several 'faults' with my COMAND unit which works fine. And yes you have to cough up forty quid before it tells you that it did not actually find any ECUs...
To be fair, it might work better if I bought and used their own BT adapter, as opposed to the generic one I have now, but I do not know....
Update:
The German vendor of the iViNi App confirmed that when using their own BT adaptor most ECUs will be recognised, so I ordered it and will update once received.
Throwing good money after bad money? Time will tell....
Could someone please post a link to the Delphi please? I want to make sure I get the right one!
I got mine from Ebay but seller has stopped you can purchase from Ebay starting at about £70 from Uk then any problems no returning to China
2014.R2 DS150E Pro Universal Car Auto Diagnostic Scanner Interface DS150 from UK | eBay
Or a website my mate used but comes from China with good support
Delphi Diagnostic Tools & Equipment DS150E with Bluetooth and plastic box Quality A+ 2014 version - xcar360
I take it yours is a 53 plate if so the W163 does not have access on Delphi to that controller:doh:
It only does it from W164 2006 onwards :fail
Mikeyp
Sorry to be a pain but my first go on this site not sure how else to get message through, I have just purchased a 54 plate c220 estate cdi with 110,000 on clock will tax it tomorrow and go for a drive. I am an 72 year old retired mechanic my friend has a CLK and a C240?.Will let you know how I get on. Lots of toys on here to get my head round ?.MikeyP
First of all thanks again for all this info everybody.
Yes mine is a w163 so would you know if it's just this controller that I won't be able to access or is there's any more I won't be able to access.
I've seen this on Amazon is this the same one
Delphi NEW DESIGN CAR OBD2 DIAGNOSTIC INTERFACE TOOL AUTO&TRUCK CODE READER SCANNER 2014 NEXT DAY DELIVERY!!! https://www.amazon.co.uk/dp/B00NLLT8IU/?tag=amazon0e9db-21
Steve on the W163
It can only access
In multifunction
Head lamp range Adj
Other Systems
Service light reset
Airbags
Immobilser
Gearbox
Climate
Instrument
Brake
Just noticed that on my Delphi system I can tap in the VIN number & it reads out the car etc but you cannot validate it as the button does not go live ?
Most other things work OK , in fact I hooked up to a old 98 E320 D & it read out the codes& live data, seeing as it states diesels from 2004 onwards I was pretty impressed! So anyone else have a problem validating the Vin ?
I also have Delphi 150E I used to borrow my mates genuine one and found it done every car I ever tried it on so I bought one from Fleabay and it is brilliant. would heartily recommend one to you all.
Alfie
Looked at my delphi and has this
Hi Thanks for the advice, bought a Bluetooth one last week on ebay and after the usual amount of mucking around got it talking to my wife's Z4. It was able to tell me which of her rear parking sensors was faulty.
On my car however (W203 C32) it did not appear to have the parking sensor option although it did have a lot of other information.
I would highly recommend the autocom ds150e as it has a lot of options, I paid a dealer £80 last year just to plug their STAR system in to my car to tell me my crank sensor had failed (which I suspected already).
Has anyohne managed to get the Delphi 150E to diagnose which Parking Sensor has failed?
I'm new to mine but seems I'm not alone in not being able to find the Parktronic module.
