mercman1969
- May 18, 2005
Ok folks
the saga continues
Had my 60k service done 2 weeks ago on my W163
since then it has ran really lumpy...took it back to see what STAR said
Garage stated it had thrown up a MAF fault.....NEW MAF fitted and ran worse
Took it today to a great Garage in Cannock on way back from LPG service
He did a few tests and said that MAF was fine as it was showing 12 Kg/Hr and that anything from 9 - 11 was good
He also put coil packs and plugs onto ocilliscope
10 plugs were showing a 'double fire line' although a good burn time and the coil packs looked a 'bit dodgy'
As he had fitted me in as a favour he didnt have the parts or time to do the job
Question is
Where is best place to order coil packs and leads from
Am going to change these...thought maybe at 1st garage hadnt gapped the NGK plugs right or maybe hadnt replaced them at all...we will see
It also isnt showing any codes for any injector shut downs due to lumpy running
you think this will cure the problem or would you look elsewhere 1st
the saga continues
Question is
