Hood ... We are talking about a soft top , yes ?
Not a bonnet catch.
2rivers,
Where do you live? Couldn't you find anyone competent that was closer?
I'm curious as to why you felt it necessary to pick a place that required a 160 mile round trip for something that sounds like very basic work.
Also, why you didn't take it back to the first place, the one that had recharged the AC when it had a leak? Surely that was the place to start with the AC fix since you'd already paid them for the gas which leaked out 'cos they didn't spot the leak.
Re Colin Ferns
I took my w124 cabriolet to them after reading glowing reviews on this website. Worst mistake ever. They did not do what was requested. they failed to pick up a clear leak in the aircon condenser (when i t had been booked in because the aircon was not blowing cold, and they had been informed it had recently been re-gassed).
The customer gave no indication that the A/C had recently been gassed. If it was then whoever did it should have put tell-tale dye in it. If we had been informed that a previous and recent re-gas had failed then we would have looked for signs of leakage by means of that tell-tale dye.
As it transpired the customer chose to return during lunch hour. That’s unfortunate but we start at 7.30 and finish at 5.30 and take lunch between 1 and 2. Colin is insistent that all members of staff take 1 hours lunch at the same time so that they can each enjoy some peace and respite from a very busy workshop.
There are other issues. The trim that covers the hood lock on the rear valance was fine and in place when the car was dropped off with them. they were asked to adjust or align the hood as it didnt quite close wihtout being helped. they fixed this, but i suspect broke the plastic catch on the trim as one day later, its missing from the car.
The customer SUSPECTS (assumes) that we broke it. If we broke it (and we didn’t) then we would have said so. When the customer returned at lunch time the offending part was present. We know this because the roof was down when he returned and the part was clearly present.
They are not interested in taking any responsibility and i will avoid as i found them to be no different from any other back street london garage. what reputation they had must be based on past service levels.
The customer took it upon himself to wander into the workshop without first bothering to ask permission and the presumed to communicate directly with our technician, whose first language is not English and who is unaccustomed to speaking with customers. This is the technician WHO HAD SACRIFICED HIS VALUABLE LUNCH BREAK to attend to this presumptuous customer’s demands.
When they called to tell me the car was ready, i asked them if the aircond was fixed and was assured it was, all checked and tested, no leaks etc.
We carry out a vacuum integrity test with every re-gas and will only re-gas if this test is passed. Unfortunately, the test is not conclusive and it is often the case that a system that has passed the test actually has a leak, hence the tell-tale dye to assist with locating any leaks.
I live 80 miles away from them and they knew this. I travelled up to pick up the car. i drove it away, within two miles noticed the aricon was blowing warm air. thought it might need some time to get cold. two more miles later, still warm. phones them immediately from the car. they said, bring it straight back (i was only 4 miles from them, 6 minutes drive). drove straight back to them to find they had all gone for lunch. didn't tell me they would not be there when i got back. useless.
The customer lives a long way away, we had no idea how close or far he was or exactly when he was going to bring it back.
Leak in aircon system found within minutes of it going back up on the ramp.
Because we put dye in the system when we gassed and it showed that the condenser was leaking.
clearly they didn't check it properly
Clearly we did everything that could be expected of us. When we told the customer about the failed condenser we asked him if he’d like us to source him a new one. He abrubptly declared “No, I’ll get it myself”. We tried to explain to him that they are very difficult to get hold of and neither Mercedes or any of the usual suppliers were able to supply one. He ignored us and insisted that he knew best.
The customer had originally complained about a lack of kick-down. We thoroughly checked the kickdown system (cable adjustment, switch and vacuum) and could find no fault.
Colin actually took it upon himself, despite being extremely busy, to take this car for a test drive himself, as a means of giving a new customer good service with some additional input from himself. Colin reported directly to the customer that the kickdown was working fine but that the engine was holding back and that it was symptomatic of air mass failure. Colin also reported to the customer that the engine mountings were perished and that there was some play in either the rear sub-frame bushes or diff mountings and that the exhaust was noisy. The customer looked at Colin as if he were something nasty stuck to his shoe. (Colin didn’t announce himself, he doesn’t like to be seen as “the star of the show”).
and for that reason, the slipshod way they operate and the lack of responsibility for breaking a component (the only logical explanation for the hood latch trim going missing after they had it off and on again)
There are other possibilities but the customer refuses to entertain them.
I will avoid in the future. I only put this comment up so that it balances what might otherwise be misleading glowing reports. They had every chance to offer to solve the hood latch trim situation, but chose to wash their hands of it.
We chose to wash our hands of AN UNREASONABLE CUSTOMER AND WILL CONTINUE TO DO SO FOR OTHERS LIKE HIM.
When i picked the car up, the seat belt butlers were not working either. they worked fine before, then i noticed they didnt work when i picked it up. when i pointed this out, the mechanic started fiddling around in the fuse box. he didnt know what he was doing, but eventually they started working again and are still working. when i asked what he did to make them work, he said "i dont know"
It is unlikely that anyone having to pay someone else to repair their car is qualified to make the judgement, “he didnt know what he was doing”. It is a well known occurrence on 124s that the aged fuses corrode and cause poor contact. The technician (yes, the one that should have been on his lunch break) simply rotated the fuse to restore connectivity and the seat belt butler worked again. A successful outcome and no charge!
As I said, I won’t be making any further comment. We are quite satisfied with our professionalism and behaviour. In fact, Colin has employed me because he would deal with customers like this in a very different way!
It's a shame when a reputable London specialist ( and Colin ferns definitely are) have to come on a public forum to defend themselves. It's true that vehicles do pass a vac test but unfortunately can still have a leak.
Having spent a fortune with these guys I can certainly say I would NEVER go back. Things never got fixed, still paid through the nose and they are rude and terrible.
WG M-B said:That's pretty unreasonable as a first post on this forum! You could introduce yourself in the correct section
